This command enables or disables a Convergence End Point (CEP) detection type on one or more ports.
| port_list | Specifies ports to configure for CEP detection. |
| all | Specifies that all ports are configured for CEP detection. |
| cisco | Selects Cisco type of CEP detection. |
| lldp-med | Selects LLDP-MED type of CEP detection. |
| enable | Enables CEP for the provided type. |
| disable | Disables CEP for the provided type. |
By default, CEP detection is disabled on all ports for all types.
This feature requires that ONEPolicy is enabled on the switch (see enable policy).
The following example configures CEP detection for Cisco type on port 3:
# configure policy convergence-endpoint ports 3 cisco enable
This command was first available in ExtremeXOS 22.2.
